Upgrade
I got a grommet at home depot to do mine. after lookin at my car it'd be simple to drill a hole through it. although I'm prolly gonna drill one in the floor not the firewall simply bc itd be easier. oh and I've got the hatchback, shootin for a mid 140 setup with 1 15 and stock alt but not so sure that'll happen
yeah hopefully when I replace my bat and alt ill be able to turn the gain up some more on my amp. its only at halfway right now because of clipping issues.
how so? my gain isnt even turned up halfway? is that a wrong statement?
The gain is not a volume button.
To correctly set your gains, you need to match it to your headunits voltage output. Which requires a DMM (digital multi meter).
To set your gains:
Take the watts you wish to produce and divide that by the ohm load of your subs. Then find the square root of that number. Remember this number.
Buy a DMM that measures AC voltage.
Unplug your subs from the amp.
Play a 50 hz sine wave recorded at 0 db.
Set your headunit volume to at most 3/4.
Measure the AC voltage that your amp produces and raise the gain until it reaches the number you found above (watts/ohms, then square rooted)
Do not pick a number of watts that your amp cannot produce.
Do not pick a number of watts that your speakers cannot handle.
If you use bass boost, find out what frequency it boosts, and play that as your test tone.
You shouldn't use bass boost, because when used correctly, you will drastically lower the output of all frequencies except that one boosted frequency.
Yes, your box's design can compensate for this, but an eq will do a much better job. Your better off just leaving bass boost @ 0
If you listen to rock music, then a nice set of components and epicenter would be your best bet.
If you like rap, then it depends what your not satisfied with. If want a better front stage, get a nice set of comps. If you want more bass, then I'd recommend DC subs and Sundown amps.
links to subs and amps please?
ccab
For The Horde!
ccab
Southern Georgia
shayne1134
