undercar neons
read the manual if you need help i can't help u i have them but my kit is way diff to what you would get mine is custom $700 per side color flip red, blue and green it looks awesome the instal took me 2 weweks to do i had to make perspex covers for the tubes cause they are real glass
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
Originally posted by bass_mekanik read the manual if you need help i can't help u i have them but my kit is way diff to what you would get mine is custom $700 per side color flip red, blue and green it looks awesome the instal took me 2 weweks to do i had to make perspex covers for the tubes cause they are real glass
what kinda car is this on?
This won't help anyone on actually installing any neons but... ****! bass_mekanik that is a sweet setup. I get chills just hearing about it. How did you even come across the idea of doing that multi-color neon to your ride? I stick to a straight blue theme.
putting them on is simple. All you do is install the clamps. There should be a big power inverter that comes with them. Just mount that under the car as well to the frame if you can and it will ground. Find a lead wire to hook up for power and then run the wires for the toggle switch to the inside of the car.
My advice for hooking them up????? dont drop em //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
dude, its pretty simple to install just need to drill holes in frame screw clamps into them but i made some metal clamps that i put on my ends so its harder to jack, but as taylor said mount the tubes so you CANT see them, it does look like $hit but otherwise good luck man
alright guys... i think i can do this.
anybody from texas???
someone told me that its illegal to have the undercar neons periods, but someone else told me that its only illegal if the bulbs are visible???
anybody know?
i have never been booked but i don't drive with them on but when i sit in the carpark boomin i have the on multi colour flash boom red bang green thump blue thump blue and red lots of cool colours and different tones create diff effects (flash rate colour and brightness)
ps i will get pics asap
It's illegal/distracting if you have them going while you're driving, but if you're parked and just hanging out than it's okay. Same thing with the little strobes some people put in their head-lights.
I installed my Streetglow green underbody neon kit in a matter of 3 hours. Most of that time was wasted in letting the paint on the steel "L" flanges that hide my neon tubes on the sides dry. Its really easy to do as long as you are comfortable with popping some interior body panels off and drilling a hole in your dash for a switch. The end result is VERY much worth it.
chinxtaboi
chinxtaboi
tx
Q45guy
