Two XX-Hercules, but how?
Ali1
e6300 FTW
How do i hook up a pair of XX-Hercules without strapping them? I currently have one XX-Hercules hooked up, but i plan on hooking another. Basically, running an amp to each R.
What about the remote wire that's going from my HU to the current Hercules. Would i need to splice the main wire at the end into two short wires running to both amps OR can i run two wires from the HU to both amps by splicing the wires at the HU?
Specifically, how do i hook up the current RCA cable to both of these amps?
As for the power and ground, i would have to use DISTRO-BLOCKS, is that correct?
come off your first herc outputs rca's to your second herc input rca's,and i would strap them.just jump remote from 1 amp to the other.
So i would still use one run of RCAs? one of the sides go into the output of the 1st amp, the other side of the RCA go into the input of the second amp?
As for the remote wire, i could keep the current remote the way it is, then add a short wire from the remote terminal on the current amp to the new amp?
thanks for helping
you plug in the rca's from your hu to the inputs of the first amp,then you get a second set of short rca's and come out of your first amps outputs to your second amps inputs.
sounds good, where can i get a short set of RCA wires?
Ali1
e6300 FTW
Ali1
U.S.
jeepintn
Mike Mccabe
