Two Dual 2 ohm CVR's - Series or Parallel?
kickerbump
I have 2 Kicker Comp VR's Dual 2 Ohm in a kicker ported box.
If I connect them in series will I get a 2 Ohm or 4 Ohm total load going to my amp.
If I connect in parallel will I get 1 Ohm or 2 Ohm?
I was think about using the Alpine M650 which is 600 watts at 2 Ohms. Does that mean 300 watts for each of my subs or 600 each?
Or should I get the Kicker 750.1?
Sorry for the noobish questions...I have been getting so many different answers from people.
If both subs are series-wired themselves (4 Ohms each driver independently) and then series-wired to each other you'll get an 8 Ohm load.
Parallel-wired themselves (1 Ohm each driver) and then paralleled to each other will yield a 1/2 Ohm load which I wouldn't at all recommend attaching to your Alpine amp.
With Dual 2 Ohm subs and the likelyhood you're not going to want to spend the money on an amp that will support a 1/2 Ohm load I would suggest wiring those subs to a 2 Ohm nominal load then getting an amp that will output sufficient wattage at that load.
Wire like so:
The output rating is total output which means if you present the amp with a nominal 2 Ohm load (regardless of how that load is achieved) you will get 600w from it. If you achieve that load by using 2 subwoofers then the 600w worth of output is shared between the two or 300w each driver.
If you already have the Alpine then stick with it as the extra wattage from the Kicker really wouldn't be worth the extra expense.If you're still shopping, however, I'd go with the Kicker definitely. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Wow, thanks alot....I have my subs wired like that diagram (series). So I should be outputing 2 ohms to my amp.
I haven't got either the alpine or kicker amp yet. I have the kicker 300.1 which I got as a deal a while ago...but it is weak and these new CVRs need more power. I like kicker but is $200 more really worth getting the kicker over the Alpine???
Thanks again...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
kickerbump
kickerbump
Buffalo
blackbonnie
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
