Two choices
LosIsATool
After I've studied a lot of combos on paper I have narrowed down to two. The only difference I see is the price gap.
The set-up is:
2010 Scion tC
Alpine HU
Alpine KTP-445
Hertz ESK splits
Hertz DSK Coax
Alpine MRP-M500
2 JL 12W0v2s
Pre fab vented box
Its time for a upgrade, I've looked around on Scion forums and came to the conclusion the stock electrical will handle up the 1500 with no problems but I'm going with 1200.
I'm starting my box build this weekend, 3.6 at 32HZ and 38si of port.
Choice #1
Audioque AQ1200D
2 Street Duty SDC2.5-12-D4 Subwoofers
RF 4AWG kit
Kinetik 1400
Big 3
$950.00
Choice #2
Sundown SAX-1200D
2 IA Lethal Injection 12s
RF $AWG kit
No electrical upgrade
$900.00
If I really dont need to change electrical the I thing the IAs will be better BUT if I dont the AQs are only about $600.00.
Tell me what you think, I'm pretty set on these choices for availability reasons
The Kinetik will be a replacement.
---------- Post added at 04:01 PM ---------- Previous post was at 04:00 PM ----------
Even if its on 12v not getting the full 1200? They do both rate at 14v right.
I would add the Kinetic as a second battery in the back and grab some KCA 1/0 for a run to the back. the KCA runs like 2 bucks a foot. Even so if you decide to do the 4ga kit knu sells a kit for 40 bucks ish.
If I were you I would also tune to 30.
The big 3 is also a must for this.
with 1200rms most cars today are ok without a extra battery.
i would def run 0 to the rear of the car if ur planning on keeping that way when ya go bigger or wanna run a lil rear battery ur ok. the big 3 is cheap and can be done pretty ez.
you want to make a system that is ez to build on. buy a 1200rms stackable amp and a good 12" sub with a ported box. soif you want to get louder you just need another sub then can grab another amp. ur 0g will be already ran for you to put a 2nd rear battery.
only thing you will have to get rid of is the box for a dual.
i 12" and 1200rms in a trunk car done well can ezly do 142-143dbs legal... just my .02 cents
Thanks for all the inputs.. I was thinking about the one sub option but do a single Fi BL15 but i just cant get the box big enough for it. UNLESS i do upfire and wall off the trunk to keep the sound form bouncing back down. 1 12 would work!
LosIsATool
LosIsATool
Pensacola, Florida
whitedragon551
