Two 12" L5 wiring problems. (Diagram)
As the title stated I have two 12's, they are 4 ohm DVC l5's.
>sonicelectronix com/item_11355_Kicker-Solo-Baric-L5-08S12L54.html
Specs say they handle about 600 rms and 1200 peak. I am powering them with a Hifonics Hifi1500d amp, it is a 1 channel class d mono amp. It is rated for 1 ohms, which is what I want to run the subs at since they are not hitting as hard as I'd like.
>sonicelectronix com/item_22707_Hifonics-HFi1500D.html
Now currently I have them wired as the diagram on the kicker website says, which on the kicker site which states they would be at 4 ohms with the coils in parallel and woofers in series. I want to drop them down to 1 ohm, but where I run into the issue is I have the box to go through as well.
It looks like this, and no other diagrams I can find say anything about the posts having the dots on them.
Kicker says that is 2 4 ohm DVC subs running at 4 ohm correct?
Now can someone please explain how to drop them down to 1 Ohm, ever diagram I see is just them wiring it out of a box or in a ported box, or different than the last one. It's ridiculous.
I appreciate the time.
Wire pos to neg for each coil on each woofer, run a pos/neg from 1 woofer to the other and run a pos/neg to the amp from the same coil that connects the subs
---------- Post added at 06:37 PM ---------- Previous post was at 06:36 PM ----------
Or google "crutchfield wiring diagrams"
So like this then? If so I tried this way and it did not work, and by this I am referring to the diagram I've made myself. I thought I made it apparent the other diagrams that depict the wiring without a box cause me a great deal of confusion. pls halp
StellarReality
StellarReality
Lake Charles, LA
IonRL205
