Twin supercharged+nitrus GTO
so how does adding a turbo to a supercharged set up eliminate the turbo lag that didnt previously exist?
i was talking about intertwining the two. not adding a turbo to a supercharged car. i just used his question as a reference. And he could've decided to go turbo, then gone with the supercharger again to eliminate the lag generated by the turbo needing to spool up.. Theoretically.
Asshat.
o man u bout to get flamed
why? its just a question...
the car was supercharged to begin with, then he added the turbo, someone said it was pointless in their oppinion. then eugenics said that adding the turbo to the supercharged set up eliminated the turbo lag.
if i have read something wrong, then feel free to correct me. but ive read it all the way it has been written.
if it was someone adding a smaller supercharger to a feed a large turbo, i would understand the logistics of it. but the way it was worded, and the way i read it, was that it was the other way around.
feel free to correct me, or the way it was worded originally. no flaming needed, just a clearification //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . calm down 06er
Asshat.
thanks for the explanation.
now, stop being a little bitch... you said what you said, i went off what you said... perhaps next time just make a concious effort to say what you mean and you wont have a problem...
no need to be rude. i went off of what was typed. not my fault what was typed was ridden with syntax error.
Children Children...
Fun Fact time...
In older Two Cycle Diesel motors they used to use a Turbo and a Supercharger...
See learning is fun...
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I'm sorry you can't help yourself from jumping on little errors to point out completely irrelevant observations. And instead of being normal you chose to act like a 12 year old. Yet you're the one calling others little bitches. CLASSIC. Its ironic that a child like you has the audacity to point out errors in MY logic and posts when you can't even spell conscious correctly.
Actually, adding a turbocharger to a supercharged car would still negate any turbo lag that would be caused by converting it to a turbo setup. And since the turbo is what is feeding the engine it IS a turbo'd setup, fed by a supercharger. You failed to even think of that. Instead you went on flaming.
And its clarification, post Nazi.
Trey803
GAMECOCKS
Trey803
SC
joetama
