Tweaking Merlin D2 for 10w7
makaman
sup,
I was curious if anyone was running this combination of m2d2 and 2 10w7s. How did you go about configuring your settings on the amp?
If not, is there a certain rule of thumb i should follow while adjusting the settings?
thanks!
maka
wondering if any one can help with som tuning.
It doesnt sound right on most songs. im a little confused as to what the different settings are on the amp and also which is the gain.
I also wanted to check if im running the speakers the right way, i have the + and + connected to each other in the box and the - and - to of each speaker running to ONE (1) connector box + and -. I then have that running to the + and - of the amp. Is that ok? or should it be 1 set of wire for each sub to the amp?
thanks!
maka
You will be getting about 1500watts, a bit to much power.
1500 watts to both correct? so like 750 each?
also anyone know which one is the "gain". The US amps has level, sub sonic, LPF, and Bass EQ. I read Jmac's thread on the test tone, but dont know which one to start turning up for voltage reading. I want to assume Level, but then dont want to break it //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
thanks!
actually could some explain what these do? sub sonic, LPF, and Bass EQ.
I have the manual next to me but there is nothing specific on what they do.
makaman
makaman
rocklin, ca
PatFitz9
