Tuning Diamond 1500.1 amp
cdpcp3
i have a diamond 1500.1 amp pushing two d6 12s in a ported box, mostly listen to rap
any suggestions cause i dont wanna **** it up and ive read the gain tutorial and im stilla little confused
i dont have time until friday to make it to a car audio shop
Suggestions as to what?
What are you wanting to know?
Are your D6s D2 or D4?
What final nominal load are they wired to?
Figure out your target output wattage according to the resistance you are showing the amp (nice amp, btw, I run one as well) and follow the gain setting tutorial in the amp section.
Done.
2 d6 4 ohm wired to 1 ohm
i really just want the most bass out of the subwoofers, but i dont know how to mess with the amp settings
i also have another one of these amps, theyre badass, had a d3 15 and a 1000.1 and it still knocked and have had plenty more diamond stuff
Alright.
Then following the previously mentioned gain setting thread set the output for 1.5kW and go on about your day. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Set the crossover to what's appropriate for your setup/tastes and the subsonic filter for what's appropriate to the enclosure you're running if ported.
You've got some really nice gear for such a novice knowledge level. Good choice, though. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
As indicated by my sig I'm more than a bit of a DAT fan. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
cdpcp3
cdpcp3
Bay Area
Prowler573
