Doesnt matter if its under rated or not. Headroom is good. You do the equation based off of RMS power.okay so i did the equation. it comes out to 31.62v for my cadence. but its under rated. it has 2 30a fuses so it should handle 600w rms at 2 ohms instead of 500. so do i do the equation using the 600 then? comes out to 34.64v but i don't want it to run the 500 or 600. prbly closer to 170 because i only have the type rs hooked up to it and i don't want that extra draw. so can i do the calculations with that? that would be 18.43v
Yeah you really probably don't need to bother with the dmm. Distortion is pretty easy to hear with full range speakers, much more difficult with subs.okay so just run music when I'm tuning the speakers and adjust to the level i like. then unplug everything and play the 1khz and check with the dmm. might try it.
