TS-WX206A... Please come in!!!
showmak
I am planning to buy the Pioneer TS-WX206A Active Bass Box...
FYI,
I am not looking for Loud bass, what I am interested in is a subwoofer with an average loudness and quality, will be used for lounge musics...
Key features
Built-in MOSFET 150 W power amplifier
20 cm Ø IMPP composite cone woofer with Strontium Magnet
Large dual port bandpass design
RCA/speaker level inputs
Input level control/phase switch
Built-in variable LPF (50 - 125 Hz, -12 dB/Oct)
Aluminium die-cast heat sink
Nominal output power: 60 W
35 - 200 Hz, 107 dB (in-car), max SPL 128 dB (in-car)
Features
Frequency response 35 - 200 Hz
Sensitivity (1W/1m) 107 dB
Maximum input power 150 Watt
Woofer size (cm) 20 cm
Woofer material IMPP composite cone woofer with Strontium magnet
Built-in amplifier 150
Built-in variable LPF (50-125 Hz, -12dB/oct.) Yes
Enclosure Volume 18 liter
Input gain control / phase switch Yes
RCA/speaker level inputs Yes
Dimensions (W x H x D) 274x316x412 mm
According to the specs, what do you think the SQL is???
Please try to give me your comments/suggestions/recommendations asap.
For more details http://www.pioneer.co.uk/uk/products/25/130/201/TS-WX206A/index.html
Cheers,
showmak
showmak
Ohio
showmak
