ts-d1320c
Fi-brations
I'm pretty sure im going with these for my 00 bmw 528i, i will most likely get an amp for them, but im not sure how many watts i need. It says max of 180, but i read a review that said that was for the whole set not individual speakers, can someone help me out? im looking a jl audio amp 110watts/channel, would that be fine? or what- thanks
Ok this is a noob question, but can i run a 4 channel amp to just one set of components(so that would only be using 2 channels, right?) and just not use the other 2 channels?(this would be in case later on i want to get some rear speakers as well)
i already got 2 fi audio q 12s on a soundstream tx1.2000d
---------- Post added at 06:36 PM ---------- Previous post was at 06:35 PM ----------
O nice will then use the other channels for rear fill
be careful with those words around here!!! you'll start a riot!
Hahaha thanks guys, i love them, i have another question, all this is kind of confusing, can my factory amp power my rear speakers and have another amp powering my fronts and all connect to an aftermarket head unit?
I'd say disconnect the factory amp and run the fronts off your aftermarket amp, and at the very least, run the rears off the HU power. Depending on your stock rears you may be able to run them to your new amp too until you can replace.
Fi-brations
Fi-brations
Memphis, TN
Fi-brations
Mike Mccabe
