1.) i dont much about this stuff, so what exactly is a crossover. Does that term mean the same as a high or low pass filter.
Oh boy, you have a long way to go. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Yes, in basic form, a crossover is a filter. A crossover "tells" what frequencies to go to which speakers. Lots of crossover info is posted at
http://www.bcae1.com.
My deck is a Alpine CDA-9856 with ~7-+7 for the bass and the subwoofer volume on it goes from 0-15. I cant get the EQ to work on it anyways, so i guess that doesnt matter. I will not let for some reason. and i always have my BBE at setting 1. I always have my system at bass 2, treble 2, BBE 1. so when i do this gain setting, have it at those settings correct?, and dont go over those settings once its done correct?
That's correct. What you want to do is establish an absolute maximum for your listening level. That doesn't mean listen at that maximum at all times - in fact, doing so will probably destroy your eardrums. But what we're trying to do is make a limit.
Keep in mind that your model doesn't have an EQ. Just bass, treble, sub, and BBE settings basically. I would recommend keeping BBE off - it can add some nasty distortion at high volumes.
when doing the gain, should i put my sub volume at 15, so that that woiuld be the absolute sub volume after its all done.
A maximum, yes. +15 on the Alpine decks sends a full-voltage signal through the RCA's to your amp.
SOme guy before said the sub volume on the deck sends distored signals to the amp. is this true? and my volume goes up to 35. so i should have it on 26 correct? i havent touched anything yet since i got it installed, but i have looked at the dials and such.I think right now the subs start getting clipped at a volume of 22-23, because the subwoofer significantly lowers in pitch at this volume up. I didn't know what was going on at first, but now i realize its clipping, correct? i hope i didnt damage anything.
The sub volume thing - it's not true. Set it at +15 for the gain setting. And yes, from memory, 26 on the new Alpines is where it starts to clip. Don't turn it up above this level. Your subs could possibly have been clipping, it's hard to tell over the internet. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
2.) you said to test a frequency of like 250. Rightn now the low pass filter frequency is set at 100. If i change it to 250 or whatever the highest it will allow me, when im done setting the gains, do i change back to the 100 mark... can i leave it at 100, or is it just harder to set the gains on that frequency.
Right, set it as high as it will go, but just for the gain setting process. After you're done, set it back to 100 or whatever (80 is generally recommended).
3.) if i want to disconnect the speakers, what would i do. Just unplug the RCA cables right, since i wouldnt have to unscrew anything.
If you're running a separate amp on the front speakers, disconnecting the RCA's would work fine.
4.) when im doing the gain on my speakers, should i turn off the subwoofers via the option on the deck. would that be ok? wouldn't that make it easier to set the gains.
That should work fine as well.
5.)Should i have bass boast off completely on the sub amp. on the 4 channel amp powering the speakers, whats a good high pass frequency to set it on and test it on.
I'd recommend turning it off completely. For your front speakers, use a 1000 Hz frequency.
Actually, try setting the gains using this method on your front speakers first with 1000 Hz before doing your sub gains. At 1000 Hz, it's VERY easy to tell when the tone is clipping. 1000 Hz gets loud, so use earplugs. But you'll hear the clipping loud and clear.
