Trying to find an amp
djXternal
Hey guys,well I've ben out of the car audio world for awhile since I sold my car, but soon will be upgrading the system in my jeep
I'm planning to run a single 10" RE SR which is a dual 2 ohm Voice Coil and runs at 300W RMS
If I looked things up correctly, then I can run this at 300W at 1 ohm or 4 ohms
I'm trying to find an amplifier to use for this. Size of the amplifier is extremely important since space is very tight, I am just not sure whether I should go with a mono amp or 2 channel or what brand to look at for both price efficiency and quality
at 1 or 4 ohms you have alot of options. You can Strap a 100Wattsx2 channel amp to it strapped for 400 @ 4ohms. That will also allow you to have a 2 channel amp for the future when you decide to upgrade.
I am not sure of the dimensions I have to work with yet, I am still in the very early planning stages, upgradeability is not something that is necessary because there really is no room for anymore than this 1 10" in the Jeep...
I would prefer to run the amp at 1 ohm (cheaper to buy generally).
Louisiana CRX - So this SR sub would run 600W @ 1ohm just fine? If thats the case then I would want an amp in that range
djXternal
djXternal
Tampa, FL
djXternal
Mike Mccabe
