adjetta
Okay so i want a daily groundpounder, I don't need crazy spl, but I want a good mixture of sq, pressure, flex, and low end authority. I can't fire the subforward due to the opening only being at max 16 inches tall, and I don't want to angle the woofer, so top fire is my only option.
still in the process of piecing my build together, running either a sundown z v4 18 or an Fi SP4 18 on an aq2200D. and yes I know a 15 would open up more options, but my heart is set on an 18...
My biggest concern is port placement, what should I do?
can I deaden the rear dash and seal it off completely along with the trunk, and fire one or two large diameter aero/aeros into the cabin? or port through the rear dash?
is a 4th order possible with a 12 inch deep woofer and only 15-16 inches of box height?
these are other ideas
Side port? center port rear firing? front firing without sealing off? top firing?
Using 8" or 10" or 12" inch Aero ports, tuning at or around 33-34hz
