truck enclosure help.
What subs do you have? What are the specs on them? If you have 12's, then you really should be looking at a compact sealed enclosure for the truck. The manual on your subs will tell you what ft^3 the subs tend to like. That is the box you should be looking for. If you can use WIN ISD, plot your subs and play around a little. Find what they seem to like best. I can tell you now, if you just go buy a random box, or set of boxes chances of you being happy are slim. Remeber, you also need to consider mounting depth with a truck as well.
BTW, it is possible in a reg cab truck. The setup in my sig is in a 95 reg cab chevy. It gets nice and loud.
This is what i found on the specs on the subs im running, there audiobahn AW1200Q's
Technical Specification
Sensitivity: 92.7 dB
RMS Power Range : 50-700 Watts
Peak Power Handling: 1400 Watts
Impedance: 4 Ohm
Low Frequency response: 20 Hz
High Frequency Response: 500 Hz
Diameter: 12 Inch
Features
Optimized for Maximum Sound Quality / SPL
PHAT 2" Foam Surround
120 oz. Magnet
Non-Pressed, Non-Transfer Paper Cone
KM3 Coated Cone for Low Cone Distortion
Bolt-Tight Cast Flame Basket
Multi-Connect Lug-Lock Terminals
Mounting Depth: 5 5/8"
Hole Cutout: 11 1/8"
Outer Diameter: 12 3/4"
Priced per speaker
Size 12 -inch
Impedance 4 ohms
Cone Material Non-pressed pulp
Surround Material Foam
Sealed Box Volume (cubic feet) 0.718 - 1.63
Ported Box Volume (cubic feet) 2.064
Port diameter (inches) 4
Port length (inches) 12.3
Free-Air No
Dual Voice Coil Yes
Sensitivity 92.7dB
Frequency Response 20 - 0.5k Hz
RMS Power Range (Watts) 50-700
Peak Power Handling (Watts) 1400
Top Mount Depth (inches) 5 13/16
Bottom Mount Depth (inches) N/A
Cutout Diameter or Length (inches) 11 1/4
Vas (liters) 51
Fs (Hz) 31.2
Qts 0.6
Xmax (millimeters) 12.5
Parts Warranty 1 Year
Labor Warranty 1 Year
Top of Page
i personally have 2 10's in my reg cab ranger, the largest box i could fit was 1.91 if i wanted decent leg room and im 5'10''. my knees barley touch the dash so.....The box is sealed with 2 10 l5's.....change out the 2 12's for 2 10's
sniper007
sniper007
Edinburg, Texas
juststartin
BP1Fanatic
BP1Fanatic
