truck blow through
Blowthroughs, bed boxs, extended boxs...different names, all same concept.
The reason i don't like them is because it defeats the purpose of the truck....it is a truck for the bed. You are cutting a hole through the rear of the cab and connecting it to the bed by way of a long box....
I have just seen some bad things happen to those. I know a guy who had one built...$2000 dollar job...he takes it down the road and hits a pothole and tears the box to pieces because his bed torqued.
Most are smart enough to use an accordian type boot that flexes with the chassis, but these can lend to really bad road noise, no matter how much dynamat you use.
Others build the entire box in the bed, and then use a flexible tube to connect to the cab...this works okay, but the spl and sq are somewhat lacking.
here is some info i found i think on this site and i saved as a text file just didnt save who wrote it.
ill post it but dont ask me about it, because i havent done it.
You can only make the hole as big as you
BED wall will allow,
Your CAB wall is bigger, but you want the
holes to be exactly the same size, within
about 1/8 difference as possible.
Basically you get in your bed, and make a
decision on how big your hole is going to
be.
I have a step side, so I didn't make the
box wider than my wheel wells, so I could
slide the box in and out as i needed,
without remove my tono cover, or needing
someones help!
So I just followed the bed floor ribs up
the the bed wall and drew a verticle line
from the floor, to the little lip at the
top of the bed wall.
It's up to you wheather or not to leave a
lip at the bottom of the hole.
If you leave a lip, it should be at least
3/4 inch high to attach the crimp seal on
the accordian rubber seal, similar to a
door jam seal crimp.
then I usually leave a 3/4 inch lip at the
top of the bed wall down from the angle on
the top bed rail, you'll see what I mean
when you look at the rail.
I tend to cut the hole level with the bed
floor, so the box can slide in flush with
the cab.
If you leave a lip, and want to slide the
box into the cab, you'll have to shim the
bed floor with wood, or metal, effectivly
raising the bed floor so the box will
slide in the cab.
Many people make the box bigger than the
hole and push the box up against the bed
wall, it is harder to seal the subs from
the bed to the cab this way, but you get a
bigger box.
When I cut the bed wall level to the bed
floor, I use a metal flange,
duct sheet metal, galvanized and make a
flange, rivet to bed and rivet to cab then
use urathane caulking to seal.
then the acordian seal only has to go up
each side and across the top.
and no, the twisting of the cab and bed
did not mess this up, as I had this in my
truck for 4 years, and no problems.
so, I used an angle grinder with cut off
wheel to cut the bed wall out.
You SHOULD round the corners, not 90
degrees, the crimp seal on the acordian
rubber seal doesn't seal as good in 90
than a nice rounded corner.
I used the bottom of Tim horton's coffee
cups to make the curve.
I then use a two inch hole saw to make the
curve cuts.
So after you have the hole cut in the bed
wall, THAT is your tamplate for the Cab
wall.
I then use the hole saw to make the corner
cuts in the cab wall from inside the bed.
Make the 4 corner cuts, useing the bed cut
out as a guide and they should line up
real good.
I then use a sawsall with a LONG fine
metal blade and follow the line from the
bed wall cut from corner to corner on the
there are two layers of metal in the cab,
you'll see this when you remove your inner
trim and carpet from the back wall.
So you have to use a LONG blade
Use a fine blade with the sawsall, if you
use too coarse of blade, it may catch the
thin metal of the cab wall and warp it.
So, now you have a blow through.
Clean up all the edges with a grinder, or
whatever.
paint the edges, and let dry.
If you use silcone, clear or black with
the crimp seal, there is a little movement
between the cab wall and bed wall, I find
that silicone breaks down quicker,
I always use windshield urathane, Than
stuffs holds good!
So you'll want to cut your acordian seal
and tes fit first before applying urathane
of coarse.
If you left a lip on the bottom, you
should put the joint in the middle, so it
has nowhere to leak, then just urathane
the joint closed.
You'll want some wood and sticks to "prop"
the seal when you get it in place.
I always mush the urathane into the crimp
seal, then put it on the metal, now, it's
called Crimp seal, cause you can Crimp it
to hold better, but the urathane will grip
good enough for you.
Once you have it all on, box line the
whole seal with wood and jam the sticks to
press on the seal while it dries, in the
corners too, this will make a good seal.
Clean up your edges of urathane, if you
used the right amount, you shouldn't have
to touch it!
To run wires to the subs.
If you bring your box flush to the inner
cab wall to make it all pretty, you can
get the wires into the box easily.
If you have the box in the bed, you have
to run you wires under the truck or:
I use black pool hose, or Shop Vac hose.
I cut the hole with a hole saw, beside the
blowthrough hole as close the the inner
bed side as i can and as close to the
floor as I can.
I think the hose is 1 3/4 hole, but not
certain.
Then I cut straight through the cab wall.
Then I push the hose through both holes,
urathance for a seal and let dry.
then I trim away the hose from inside the
cab flush to the urathane seal.
TIP: If you leave your box in your bed,
and the box is bigger than your hole, you
should make a flange, or port to bring the
sound dirrectly into your cab, this way
you won't lose any bass into the bed.
I used a ratchet strap on the two tie down
hooks at the front of the bed to hold the
box tightly against the bed wall, worked
great.!
I made two boxes for my truck, one for
everyday listening and one for competing.
My every box had two 10 inch PG XS which
sounded real good.
and my competition box had one 15 stroker.
If you make your box to come in flush with
your cab wall, you don't have to recess
you subs into your box, make them flush
with the wall and make a port, sounds
good!
Hope this helps!
Subarufool
Subarufool
Pheonix, AZ
HotCarl
