Trouble getting an old amp to work
  • 4
WoodyT
This is my first time posting, so I apologize if there are any guidelines I'm not following.
I bought my car used, and happily found an amplifier under the driver seat (a Sony XM-2501) and wires run under the carpet to the trunk and the front dash. I don't have any prior audio experience, but I figured that with so much set up I would buy a subwoofer and see if I could figure it out. The head unit was replaced right before I bought it, so the audio and the turn on wires were disconnected. I connected these myself, and found that the sub had very low output volume. I spent some time debugging (this was about six months ago) and it suddenly started working when I scraped some rust off of the grounding spot for the amp. After it was working I took a drive and about halfway through it stopped working again, and it hasn't worked since (it has the same low output).
I've tried scraping the ground again, replaced the terminals for the sub-amp connection (they were very frayed), checked the battery voltage at the amp (14V), the turn on voltage (also 14), and made sure the amplification was set to the highest setting. It seems like the only thing I haven't eliminated is the audio cable (seems to be in nice condition, Monster brand), but like I said I have very little audio (or car) experience.
What are your suggestions?
Today I went out and bought new RCAs, hooked it up, and had the same result. Have to say at this point I'm confused and frustrated. The input level control (if that's what you mean by gain) is the only adjustable piece of the amp (shown on page three of the manual). There is little noticable difference when changing between min and max.
I'd second trying a different RCA cable. If you have a 3.5mm to RCA adapter (a Y that plugs into an MP3 player, but with RCA outs) you can use that directly connected to the amp to bypass the installed RCA cable. The ground should be securely bolted to unpainted (or ground off) chassis. If the connection is "rusty" that's concerning.
Seems kind of stupid to prevent helping others with advice on equipment from Amazon, doubt that Amazon is preventing this either. Pain in the arse!
14
918
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
976
Try tracking down your leak. Check your trunk, and around your antenna wire.
Back in the late 90’s, I took my S-10 to Pigeon Forge Tn for the Mini Trucking nationals. The cops there were the worst that I ever seen. They...
I'm not a big fan of Brand X personally. My car idles at 500rpm and my Autotech didn't turn on until 650. I sent it back and he redid it to turn...
852
WoodyT
WoodyT
McLean, Virginia
mylows10
    May 16, 2024
    May 16, 2024
