Tried it all, I'm stumped!
da box king
Well some of you may remeber my post saying my 100.4 was cutting in an out. Well my ppi did the same thing so I knew somethin was up.
I swapped rca's sp that was not the issue, and I grounded the rca outputs on the deck since the pico fuse just popped.
As of now its so messed up. Certain channels work at differant times, and some channels wont. I have managed to get my 100.4 front channels to work with a certain rca order. I dont get it. Both amps are doin it, and they worked gret b4. Only thing I did was take my seats out of my car and cleaned up my wiring.
I'm thinkin its my 880 head unit?//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
Well some of you may remeber my post saying my 100.4 was cutting in an out. Well my ppi did the same thing so I knew somethin was up. I swapped rca's sp that was not the issue, and I grounded the rca outputs on the deck since the pico fuse just popped.
seems like it..you tried everything else
Rem wire will make the amp shut off completely, not alter certain channels intermittantly. Plug any source unit you have with RCA outputs in and see if the problem goes away. Even a home stereo or boombox with RCA outs will work, just be careful to adjust gains or leave the volume at low to moderate levels. The key to troubleshooting is to isolate each component (including wiring) until the problem goes away.
grab an ipod and a 3.5mm jack - rca converter from Radioshak or w/e and hook it up.. see where you are at.. Hell you might have something else wrong and the only solution is Complete overhaul of your wiring including all new rcas etc if the ipod hooked up does the same thing
I will try somethin like that after I can swap the hu
lol, I believe I still have a warranty, not a fan of alpines tho...thanks man:)
Not a fan of Alpine //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Hows the Kenwood working ? lol
da box king
da box king
Portland, MI
djarmy2004
