Treo ssi 10" dvc2
tyroneshoes
886
NJ
Treo SSI 10" dvc2 subwoofer
Lightly used almost like new. I purchased it because it was shallow enough for my stealthbox (5.1" deep) but the magnet is too huge to fit unfortunately. Tested and works perfect.
These work in sealed or ported and can take pretty much all the power you give it.
PDF and parameters here
http://www.treoonline.com/infosheets/ssi_subwoofers.pdf
175 shipped in US
If your not a huge bass head, 500w will be fine and you absoulutely will give that sub no problems on 500w...these subs like smaller sized boxes as well...my 15 was only in 2.5cu net
I would re-adjust the gain after setting eq with a rta. Im just worried that Id be choking the low end and thus need more power than I currently posses. I'm tryin to keep this system as simple as possible. Deck, dc1000.4, Zapco/ESB Comps and a single 10"
I was very content with an ICON 12" with 600 watts and Im assuming this would be a similar situation.
with that space, i dont think you have the optimal power, but its worth a try
Me neither. And Id rather not put too much strain on the stealthbox which was designed for a lightweight 10w1v2 about a quarter of the weight of this sub. Last thing I want to do is strip all the screw holes and refiberlass the mounting area from behind. I hate working with fiberglass. I guess if Im ok with inverted mounting, my choices are pretty endless, but Id rather not. Just may be my only option at this point.
Id like a shop to glass a 1" spacer on to this but no shops in my area glass anymore. They just push jl. I'm thinking a tc epic is perfect for this, just need .75" more clearance or invert it.
Thanks for all the feedback as Im not familiar with this sub at all.
Still for sale. Send offers my way but please realize I am just barely breaking even.
Im thinkin the same. Just want to cover it up with a grill but I guess inverting it protects it just as well and gives it much more breathing room. Id be doing it now if it wasn't 100 degrees. I should try it before selling.
monster motors //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif My brother had a pair of ssi motors. they fit an 8 layer lul. i was pretty mad when he sold them, i wont lie though, i really just wanted them because of teh shiny
You guys werent joking. After invert mounting it, adding lots of polyfill and resetting eq and gain, this thing moves air and is right about where the enclosure size should be. The sale is on hold for a few days while I make sure I plan to keep it. Seems to work fine with 500 watts and it has plenty excursion.
Air from the pole vent. Can sound like port chuffing if youre close enough. Hardly audible from the front seat however and also depends on the sub (idmax isnt pole vented for example)
not stealthy but sekzy
tyroneshoes
tyroneshoes
NJ
tyroneshoes
