SOLD Trading: Lanzar Opti500.2 Looking for: 1000x1 amp
WheresTheButta
I've got a lanzar opti 500.2 amp, used for 2 years, has some scratches on the casing, but works just fine. Specs of amp can be found on lanzar.com Looking for a class D amp that puts 1000wrms into 1 ohm, appearance of amp does not matter, only that it works. It's what's inside that counts right? //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
pics of the amp available, I can take a digital movie walkaround of the amp if you need in-depth; no idea how to get them on here though, so if you're interested contact me via here (e-mail is bd5034@caraudio.com) or via aim: wheres the butta
SPECS
# RMS Power 450 Watts x 2 @ 2 Ohm
# RMS Power 250 Watts x 2 @ 4 Ohm
# Bridged Power @ 4 Ohms 900 Watt x 1
# THD
# IMD
# Input Sensitivity 150mV -7V
# Input Impedance 22 K-Ohm
# Signal to Noise Ratio -10dB
# Damping Factor @ 20Hz, 4 Ohms 300
# Extremely Fast Switching Power Circuits
# Stiffly Regulated Power Supply
# Bipolar Output Devices
# 1 Band Parametric Equalizer
# Full Variable X-Overs
# Line Outputs
# Wired Bass Jack
# Adjustable Gain Control
# Variable Bass Control
# Variable Phase Shift
# Variable Base Boost
# Dimensions: 10.92"W x 2.97"H x 9.84"L
# Weight 22 lbs
the opti series are some good amps people!
bump
this amp draws so much current, that's the reason I'm looking to swap by the way... that and I want an amp that takes up less trunk space since i'm so limited as it is.
I want to trade it for a good monoblock amp that puts out comparable power (1000wrms) into 1 ohm. Otherwise, pm me or get in touch on aim and we can work out a price if u want to buy. Aim = wheres the butta
Not a family member here....but I sure as hell felt like one as I devoured this thread. The ONLY REASON I vandalize this tapestry of broken hearts...
22
4K
WheresTheButta
WheresTheButta
Cranford, NJ
danteBirosel
