Towing a boat..
buy some performance brakes that are drilled slotted or both with either a 4 or six cylinder braking caliper you'll stop doing 100mph in probably 600ft the only reason why it becomes hard to brake is cuz they get hot dont ride the brakes. Use your transmission to slow you down not your brakes if you want a cheaper diesel look for an older ford like 90's my bronco is roughly 8000 lbs by itself cuz the lift i have on it and the plain and simple fact that i have 33's on it its simply a tank my stock brakes do a good job but they get hot to fast and new calipers is probably the easiest solution to any braking problem
miker
miker
Wayzata, MN
jco1385
