Too much power?
mabel4life
Frank the Tank
Alright guys I was wondering if a profile ap700m would be too much power for a powerbass PB-C156D wired to 2 ohms. Here are the specs on the amp and sub. Thanks.
Sub:
15 inch woofer with chrome cosmetics
60 oz magnet, DUAL 4ohm VC
Power Handling 300 Watts /400 Watts Peak
Sensitivity 91dB @ 1W/1M
FS= 22.7HZ, QTS=0.68, VAS=430.7Hz
Frequency Response 28 Hz - 1 kHz
Amp:
Max power output @ 4 ohm 1 x 450W
RMS power output @ 4 Ohm 1 x 220W
Max power output @ 2 ohm 1 x 700w
RMS power output @ 2 Ohm 1 x 350W
Frequency response 20HZ- 250HZ
signal to noise >103DB
stereo separation 83DB
RCA input Voltage 200mV-8v
RCA input Impedance 20K ohms
Load impedance 2-8 ohms
crossover frequency 50 HZ-250HZ
Damping Factor 300
From the looks of it no. If you chose to go with that amp you would have to keep an eye on the sub and listen for any distortion for the first week. If there isnt any distortion on the sub then it will be fine. It will even put less load on the amp and run a little cooler.
mabel4life
Frank the Tank
mabel4life
central PA
mabel4life
