to drive my s15L7 dual 4 @2ohms,what ampli should i go for:
renier
Vivo BOoOM .i.(0_o).i.
this?#1
SPECS
2x600W RMS at 4 OHMS 2x1200W Max at 4 OHMS
1x2400W Max at 4 OHMS Bridged 2x1000W RMS at 2 OHMS
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohm Stereo Stable
Gold RCA Inputs
Line Outs for Left and Right Channel
Low Pass Filter Controls
High Pass Filter Controls
Power and Protection LED Indicators
Soft Turn-on/Turn-off
THD:
S/N Ratio: >90dB
Channel Separation: >65dB
Freq. Response: 10Hz~35KHz
Subwoofer Remote Level Control
Dimensions: 9.82''(W) x 2.34''(H) x 20.47''(L)
or this?#2
SPECS
1x400W RMS at 4 OHMS 1x800W Max at 2 OHMS
1x2000W at 1.3 OHMS
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM(Pulse-Width-Modulated) System
Glass Epoxy PCB With SMD Technology
Gold plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Variable Subsonic Filter(15Hz~40Hz,24dB/Octave)
Phase Control 0-180 degree
Input Impedance:10K Ohms
Soft Turn On/Off
Heavy Duty Power Coated Heatsink
THD: 0.1%
S/N RATIO: 90dB
Input Sensitivity: 200mv~8V
Freq. Response: 10Hz~150KHz
Remote Bass Control
Dimensions: 9.82''(W) x 2.34''(H) x 15.16''(L)
i have no other choice here..pls help
i've took the first one, and then i saw that it was not possible to brigde it at 2ohms..so i asked the shop if i can still return this amp and change it w/ the 2nd 1 i mentiond..i'l be able to here my sub at its full potential w/ the 2nd amp?
but w/ the first amp,will i get its full potential?i wont risk anything?i can't return my sub..they told me that there are no more dual 2 s15l7 here at kicker philippines..what kicker amp will drive this sub?i have no budget already..they just gave me the chance to replace it cause i brought this system just last week..
2mrow,the second amp will be delivered to the shop..i must choose wisely
if there is any kikcer amp that can drive my sub w/o problems,w/o lack of power supply,then i'll try to add money to the lanzar amp i've just purchased..
any help w/ this?possibly, a low budget kicker amp..
if my first amp can drive my L7 w/o problems at 2ohms stable bridge,then i tell the shop not to deliver the 2nd amp..
ayt..thanx!if i have extra money,i'll try to get a kicker amp..
but if not,i'll try to get the best out of the 2nd amp..any other options or suggetrsions just to make my sub to its full power?
money matter..always
i have a crossover,a 2.4 cap,but they seems useless..
yea,just a cheap isuzu hilander..
i designed a ported box..hmm..8cu.ft w/ all the displacements,then 6cu.ft w/o the port..i don't know how to tune a port to get me 30htz,or lower..i don't even know what htz means..hertz,right?the only thing i know is that the the hertz is lower,the bass will woof lower frequencies..am i right?
the port it's very long,i don't remember the measure,but it was 3.5" wide..like an L shape..i took a look at MoeLester box plans..
i think tomorrow the box is done..3/4 MDF..do i need to fill the box w/ fiberfill?
i'll set the gains to its max levels to get the max out of the baric?
id say get a MaHK1998 instead of those or something like that. There like 100-125 on ebay. And seem way better than those to amps. The MA is rated at 1200rms@2ohms. But that is at 17V i think. But still a better choice then those amps at the top.
the only problem is that i can't take my money back..those are my only choice..there are also alpine amps,sony xplode amps,i wish i could have the ampli you mantiond..Memphis Audio right?
any other suggestion w/ what i have?
do the 1st sub risk to short at 2ohm bridged?
i saw the Ma amplies..i wish i could knew them..i wasted my money on this amp costing me $314..twice as the price..i'll use them for upgrades..i'll buy another L7S15 soon..but if i want to parallel them, dual 4's at 1ohm stable,what ampli should i run for?
do ebay ship overseas?i'm from the philippines..how can i order them?
renier
renier
philippines
renier
