work is based upon power and efficiency. for the most part the important thing to note is that an amps ratings for bridged mode are different then for stereo mode.
between two equivilent setups -- eg, 2 2ohm stero loads vs 1 4ohm bridged load, there will not be a difference.
amplifiers will try to have an output voltage (based upon the music played) and will supply whatever current is required to get it. bridging effectively combines the voltage from the two channels. ohm's law says double voltage means double current. so each channel has to support 2x current. power is quadrupled (over the single channel, unbridged case). but each channel is effectively driving half of the speaker and thinks the load attached is half of the actual speaker impedance (ohms).
