Sold TMA 500.1 for salez
skylineTT
bass=sekz
hey. i bought this amp last week and want to keep it but im low on funds and need teh money.
its a Total Mobile Audio (by JL Audio) 500.1 or 500 watt monoblock amp.
its true mono and is very very solid. it does rated power easy and does it at 2ohms. it is in pretty much flawless condition. the only thing noticable are the little scratches right around the mounting holes where the screws make contact but other than that, perfect shiney finish. it sounds very clean and has the gain control, X-over freq control, and bass boost control. its the 2nd nicest amp ive owned and will easily push whatever you have in line for it.
Technical Specification
RMS Power Range : 340-500 Watts
Number Of Channels: 1
Low Frequency response: 10 Hz
High Frequency Response: 100 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
Monoblock Subwoofer Amplifier
Rated Power 14.5 V: 340W x 1 @ 4 ohm
Rated Power 14.5 V: 500W x 1 @ 2 ohm
Linear, Complimentary Bi-Polar (Class B) MOSFET Design
Inputs: One Mono Pair (RCA Low-Level)
Input Sensitivity : 200mV - 4V
Preamp Output : Pass-through type with unity gain
Frequency Response: 10 Hz - 100 Hz +/- 1.0 dB
Bandwidth: 11.63" x 9.69" x 1.93"
Low-Pass Filter: 12dB/octave with continuously variable cutoff frequency selection from 40 Hz - 130 Hz
Variable EQ-Bass Boost: 0 - +12dB @ 45 Hz
Phase Switch: 0 or 180 deg.
Preamp Output: Pass-through type with unity gain
Remote Gain Control Included
Dimensions (L x W x H): 11.63" x 9.69" x 1.93"
A JL Audio Company
they are goin on the bay for 175 used so ill say 150 shipped. i will give pics if youre interested but for now, ill wait until that point. thanks
skylineTT
bass=sekz
skylineTT
Houston/Dallas
lysfys
