possibly a certain frequency range?Ive never messed with a TL. Just have a question. I noticed that on the first part of one of the songs, it doesn't measure anything, even though its audible. Does the meter only give a reading if its above a certain db, or predetermined range? Just curious.
TLs are normally setup not to read anything 120db. This can be changed in their settings.Ive never messed with a TL. Just have a question. I noticed that on the first part of one of the songs, it doesn't measure anything, even though its audible. Does the meter only give a reading if its above a certain db, or predetermined range? Just curious.
Typically I have a dual alt setup consisting of the factory 160a and a 200a, RedTop under the hood & a pair of YellowTops in the back, two runs of RF 2/0 wiring front to back (one power & one ground), RF 1/0 from batteries to the amps, and a mix of RF 2/0 & 1/0 for the big 4. 2/0 from the alts to batt, 1/0 from the batt to engine block, engine block to chassis, and chassis to batt. I like overkill.****, that's loud.
What electrical are you running?
The meter is in the kick. Thats where the local shows here place it. I'll do some on the windshield also.Where is the meter placed?
