Tiny hole in surround!! help !
silenkiller
zz
Okay, just did the ultimate idiot maneuver and put a hole in my surround. Its tiny. I'm talking like, the size of a pea. Its hard to even see. Will this affect the sound? Should I fix it, if so, how?
silicon will fix it if it needs fixed
Its pretty small, but its definitely all the way through. Should I try and fix it? Will it tear larger if I don't? The subs going to be getting 2000rms.
never poked a hole in surround but have slipped and dented a plastic cone //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
This is the first time. Blah. Why on my new 340 dollar sub ffsss
Ok, applied small amt. of clear silcone inside/over the hole/slash. Its like.. 1/32d of an inch. So small hope its ok
Slipping is part of the game brotha. Bound to happen sooner or later.
Let that silicone dry for a full day before pushin that sub hard
Right outside of Southern Highlands. Decatur and Blue Diamond road.
10
I have dealt with several blow through sub setups over the years. Forget just trying to extend the port into the cab. All that you will hear in...
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
thank you for the quick reply ,I contacted LordofBass and the part is backordered but I'm on a waiting list Cheers:)
silenkiller
silenkiller
zz
godhatescivics
    Jun 1, 2024
    May 31, 2024
