Timing?
EzRush
I'm having a little bit of an issue deciding which way I want to go with my setup. I currently have a Focal Audio 165V3 component set which comes with a 6.5" 4" and Tweets. I'm planning on running 3 way off my alpine deck. My problem is should I try to build something to put the 4's up front(The 6.5's are going in the front doors) or should I put the 4's in the rear doors(stock location of rear speakers) and mess with the timing of the rear door speakers?
I don't know how or where to put the speakers in the front so that's why I'm trying to find different options.
System Components
Lexus GS400 (98)
US Amps AX-5600 5ch amp
FI Q 12" Subwoofer
Alpine 9815.
Focal Audio 6.5" 4" Tweeter
build something. you dont want any speakers behind you...
and you want your speakers relatively close to each other.
putting them behind you will completely wreck your sound stage, you will have part of your sound coming from the front, and part from the rear, and you WILL be able to hear the difference //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I've tried searching for options on how to build something, if I could build something custom woudl it be good to put them both in the door, that is the 4" and 6.5"
EzRush
EzRush
Niagara Falls
EzRush
Mike Mccabe
