the idea is to have the output from each speaker/sub, arrive at your ears at the same time, becuse some speakers /sub are different distances from you, the time alignment feature can adjust the timing of each speaker. you need to delay the speaker closest to you the most and others less, and the speaker farthest away has zero t.a.I have the pioneer deh-9800 and have the time alignment function but dont know how to measure it from speakers
i tried today and i really improve the sq, but now i have to set the gains on the amp its a 600 something mtx and its 4 channel but i runing in to 2 bridged and feeding 2 bostons sl80 front stage but i think the gains on the left and right its not balance going to have to set the gains whit the multi meter to have them balancethe idea is to have the output from each speaker/sub, arrive at your ears at the same time, becuse some speakers /sub are different distances from you, the time alignment feature can adjust the timing of each speaker. you need to delay the speaker closest to you the most and others less, and the speaker farthest away has zero t.a.
trust your ears not the settings, if you get it right music will start to sound clear and 'up front' not 'behind you'.
Maybe by LOWER it is referring to "lower distance to the listening area". Such as inches.bump this thread to please explain why my Alpine HU Manual suggests to set a lowerms delay for my front speakers than my rear speakers. It seams bassackwards.
Won't the distance differential take care of that?Because you want the sound of your front stage to arrive at your ears before the sound from the rears do.
Lower ms = less time before the sound reaches your ears.
...what? Give your bass waves time to mature?
Don't delay your subs at all, if they are in the trunk and far away from you. Delay your front and rear speakers by measuring the distance difference between them and your sub.
A = (B - C) / 34
A: Delay time (ms)
B: Distance from listening position to furthest speaker (cm) (your sub)
C: Distance from listening position to the speaker to be adjusted (cm)
For example... Example:
If you're in the drivers seat,
B: right rear speaker 100cm
C: front left speaker 50cm
Delay time = 100 cm - 50 cm / 34 = 1.47ms - figure 1.5ms.
You need to do this for every speaker independently. You may be surprised; in some cars, your rear speakers are closer to your head than your front speakers are, and you would actually delay them more than your fronts. Be prepared to tweak it a bit, as you may not sit exactly in the same spot when driving around.
