Three W3-D6 JL's
I doubt that 3 JL w1 or 0 are gonna outbump some diamond D3 subs. Especcially since you shoudl be pported and these are sealed.
However the amount of cone area is gonna be the defining factor as well as your final ohm load that the amp see's.
The only way to really tell is drive over and hook them up. Everything else is just speculation.
2 ported subs shoudl keep up with 3 sealed though maybe not on bass mechaniks or DJ magic Mike program material.
I doubt that 3 JL w1 or 0 are gonna outbump some diamond D3 subs. Especcially since you shoudl be pported and these are sealed.However the amount of cone area is gonna be the defining factor as well as your final ohm load that the amp see's.
they're W3's //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif and they would not only outbump but also sound better then two d3's
Your amp is only 1 channel... it may have two sets of terminals and is then bridged internally.... D6 means dual 6 ohm voice coils... so your amp will see a 1 ohm load... You will power them perfectly and the w3 is still one of my favorite woofers... You sure they are dual 6s? Or are you sure they aren't w6-d6?
Bimmerdriver
Bimmerdriver
Santa Rosa, California
Bimmerdriver
