three 12"s ??? 2 15's???
psych0ticnemes1
Psych0tic Customs
First of all, i guess i need to know if a 1ohm stable amp will handle a 1.34 ohm load??? My amp does 1200rms at 1ohm at 12.5v... my blazer is right around 14v normally... so anywhere from 11-1300rms watts
My sx does get very loud... but for whatever reason it doesn't handle the power well... my gain is set accurately (right around 3/8's), so i know clipping isn't an issue... and with deep bass notes that cause more excursion, the sub makes a pop noise... (only once in a while, and it is a used sub if that matters) my subsonic filter is set right around 28-29 (for a 35htz box)
Should i get three 500rms 12"s so that i know i don't have to worry about power handeling? If so, are the compvr's a good choice??? suggestions would be appreciated...
or two 15's that can handle 700-1000rms a peice???
I'm looking to get loud WITHOUT hurting my subs... SQL i guess is what i'm after...
my budget will be right around 250 shipped max for any of these options...
first off, why would a 1ohm stable amp not be able to handle 1.34ohms?
Second, what are you looking for in a sub stage? Only SPL, SQ, SQL????
Sounds like your sub is bottoming out. BTW I heard this from other people. Anyways Im not sure but the SX is recomended for a 2.2-2.5? enclosure. I see you have yours in a 4 cub ft box=more efficient. Instead of seeing 1200-1300wrms its probably performing like its gettin 2000 wrms or higher.
ok... makes sense, what should i do though?
Different wiring config, lower gains, take it easy more often, smaller box would be the biggest improvement, different amp, diferent sub....
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
RandyJ
