Thoughts on this sub/amp combo?
kahlilj
GA
Alpine MRD-M500 amp specs:
• 200W RMS x 1 channel @ 4ohms (12V)
• 250W RMS x 1 channel @ 4ohms (14.4V)
• Frequency response: 20Hz – 200Hz
max power: 900W
morel 10" sub specs:
Sensitivity: 90 dB
RMS Power Range : 250 Watts
Peak Power Handling: 500 Watts
Impedance: 4 Ohm
Frequency response: 20-900 Hz
single voice coil
would this sub be underpowered by amp or vice versa?
Looks like a good match to me. As long as the amp does it's rated power, but Alpine amps do, right?
Yeah I think so 3rdgen. Alpines are decent quality amps from what I understand. I had one previously MRV-100M & it worked just fine... til my car was flooded //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
therefore time to replace my setup.
it depends what you mean by overpowered?
Technically speaking, there will be an impedance curve and your output power will never be what you wired it to.
IE- 250w, for example.
Averaged output will be more like 40% of that or around- 100w.
But even if you wanted to attempt to match the realistic output by using something larger like a 700w amp, for example, you'd have to take possible precautions mainly in how the signal is being amplified such as not clipping it.
Even ran for a long time, matching realistic output power could thermally stress the driver.
Generally, you'd want to double your amplifier power to the speakers being used. This is common in pro audio.
In car audio, I would typically run 2x the amplifier rated power to subwoofers and 10x for competition.
For front stage, 1.5-2x amplifier rated power.
This is all possible, of course, with fine tuning and active protection from speaker failure.
good stuff shizzon. Thanks for the advice. So for example if my sub is rated for 150W RMS, then my amp should be rated for ~300W RMS? what about the maximum rated power levels for each? Should I basically disregard those and only focus on the RMS power?
Only focus on rms..
Now, while i said to do that, its not necessary all the time either.
box volume for subs may be larger than recommended. No extra power recommended.
Extremely long duration of play need not double power.
Setting crossovers too wide open need not extra power for front stage.
Only focus on rms..
Gotcha. thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Change that amp to a audio technix AT 400.1 and you will thank your self in the end!!!
thanks but I never heard of that brand, but then I'm no audiophile either. Are they better thsn Alpines then?..... I checked out some info on them, no offense , but they look kinda cheap, but the specs seem good. Are you serious about this one though?
These amp are now called CT sounds... Very VERY GOOD for the price!!! Unbeatable quality for the price.... And you can strap those also!
I got the AT 1200.1 , took it out and put a pair of the AT 400.1's strapped on my Icon 15. Very impressed with these lil amps, almost as loud as the 1200 was
They are better then most mainstream brands out there man, puts out a lot more power then its rated for. There's a whole world of quality beyond typical kenwood pioneer alpine stuff. You'll want a 2 ohm morel sub instead of a 4 ohm though.
Dont believe me? then here's a test on their AT 1400.1 for true power.
These amp are now called CT sounds... Very VERY GOOD for the price!!! Unbeatable quality for the price.... And you can strap those also! I got the AT 1200.1 , took it out and put a pair of the AT 400.1's strapped on my Icon 15. Very impressed with these lil amps, almost as loud as the 1200 was
ok kool.
Thanks Jeff. That's good to know & believe me I know the mainstream stuff is not the best out there. I know there are better like JL audio, Phoenix Gold, and a few others, but problem is I don't know all the others. probably need to spend more time on here and reading from the experts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Any recommendations on other quality, used amps I could get with similar specs to the alpine I mentioned?
You know mainstream isn't the best but there are better such as....... Mainstream? lol.. That doesn't make sense.
There are only a handful of buildhouses that are good and then out of those, the brands who pay to get it built right.
CT Sounds was not one of them but appears to be slowly doing better.
There was a mass liquidation of their products, over $150,000 worth at monstrous savings to the customer as it was sold direct to customer so no brand markup.
CT Sounds lied about some of thier higher powered amps being durable in certain circumstances whereas the buildhouse told them not to say that but they did anyways.
Then guess what, many amplifiers died because of false specifications.
"Supposedly", they changed buildhouses for better quality. While the customer will never know the real reason, CT Sounds left the buildhouse with a load of inventory they never paid so everyone has been paying WAY below street price for them.
Because of this recent fiasco, it leaves questions in people's minds whether CT Sounds is financially and morally capable of making business decisions.
Because of this incident, a few buildhouses have now viewed the United States business as "shady" and demand money up front now with much less "friend to friend" business.
CT Sounds recognition is only shown by the buildhouses who build them and not who imports them. That leaves much in question as they continue to hop to another buildhouse.
Now, in terms of brands, there are over 300 brands of car audio.
There is no best as best covers many topics and no single company has the best of everything.
There is
performance
cost
innovation
uniqueness
customer service
warranty
cosmetics
competition focused
durability
kahlilj
kahlilj
GA
kahlilj
