You need to add five inches to the depth of the box, making it 23" deep. That will get you to 2.8 cubes. Then, you need a 23.25" long port that's 3" * 12.5 inside measurement. The 3.75" I mentioned is the gross displacement of the port, not the actual port dimension. And yes, you will need to make the port L shaped. And remember that when you're laying out the port inside the box, you measure length through the center of the port, not through one side or the other. In this case, that would be 1.5" from the inside wall of the box.
