I have a single 15" fosgate T1(4ohm)sub. Would this amp be worth considering if I can get it 3months used in the $350-385 price range?
Description Value
CEA-2006 Compliant
Number of Channels 1
Rated Power
(RMS Continuous Power) 1000 Watts x 1 @ 4-Ohms
1500 Watts x 1 @ 2-Ohms
1500 Watts x 1 @ 1-Ohm
Total Power
(Sum of Rated Power) 1500 Watts
Bridgeable No
Efficiency (average) 86.2% @ 4-Ohm
74.6% @ 2-Ohm
63.0% @ 1-Ohm
Crossover Controls Low-Pass (LP): 35-250Hz 24dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Infrasonic Filter: -3dB @ 28Hz 12dB/Octave
Signal Input Low level: 1 RCA pair
Signal Output Low Level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote Punch Bass EQ
(overrides built-in Punch Bass EQ)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class bd
Frequency Response 20Hz to 250kHz +/- 0.5dB
Shipping Weight 14.35 Lbs.
(6.50 Kg.)
Dimensions (HxWxL) 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)
Description Value
CEA-2006 Compliant
Rated Power
Total Power
Bridgeable No
74.6% @ 2-Ohm
63.0% @ 1-Ohm
Cooling Convection
Thermal
Protect
(6.50 Kg.)
