Those With DD's or AQ
Anonymous
What is the best thing to use to connect the wires together. I was looking at AQ's website and it showed using wing nuts to connect the wires, the only thing that worries me about that is in a high vibration area they will come loose. So what is the best thing to connect the wires? Also the sub has 10awg wiring for the terminals do i need to use 10awg speaker wire when i wire it up?
The best connection is with wire nuts. You can get them at any hardware store and they can be used over and over. They twist on and will not vibrate off. You can tape over the wire nut if you are worried about vibriation. They will give you a copper-copper connection. The next best connection is simply stripping the wires about an inch and twisting the ends together and tape.
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I always use the big red wire nuts...and always tape mine so they don't vibrate loose...
me too, i do the same thing, i love the red ones especially when using 8 guage speaker wire //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Anonymous
Anonymous
Cantonment, FL
B_Campbell
