those of you with SUVs......
I put a comforter in between the back hatch and the box. Works good, and believe it or not, it doubles as a blanket on road trips! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I do not have a hatch, but I do have two cabin doors. The pillars above the tail lights rattle internally a little bit if I am playing heavy bass, nothing much though.
i had an expedition and i had to use expanding foam. which worked great cause i shave off the high points then put the panel back on. after that the only thing that rattled was the rear window wiper but it just pulled it off cause it stopped working anyway
Mine do too, quite a bit. Im wondering if I can pull them and deaden them.
How easy is it to work with expanding foam?
From what I have seen, easy if you have a hole to insert it in. If you want to take it off and fill it then put it back on, you may have some problems. You basically squirt this stuff in, and then it exapnds //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
zachzchw
zachzchw
ohio
Expy2K
