^^^^ use your ears within reason -- just dont expect to have them last long if your RMS power is near the peak power handling of the comps... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Remember that peaks in your music can be 20-30dB higher than the average level... a little thing called headroom... likes to send your 300 watt amp into light clipping even if you are only listening at a mid 90dB average listening level //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif -- aka watch your tweeter //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah i've been thinking about bridging my Orion 8004 to Focal K2Ps which would give them 400w rms per. But got to thinking that i'd probably have to set the gains so low that it wouldnt be worth it in the end. Am I right?My motto: don't waste 4 channels of power when you get more than enough juice for the set (without strain or distortion) on 2 channels (and use your other 2 for something else).
That's how it turned out in my case, only. Every install is very different.
If I had a 50x4 @ 4 Ohm amp, obviously I wouldn't want to tap out my amp trying to push the hungry PG Elite's on only 50 Watts if I had 200 available by bridging the amp's channels. But, 400W each is too much. Gains set so low, it's just wasted amplifier capability.
NGJust because you have a "180watt" rms amplifier (180 x 2 rms or whatev) doesn't mean you're sending you speakers 180 watts. Use a DMM and a 0dB test tone and set those speakers to 180rms power using AC voltage...and I guarantee you they wouldn't last long //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Me, I like head room. You can get an amp that is rated at TWICE the rms power, but that doesn't mean you're sending the speaker that much power. It depends on input signal strength, gains, etc.
NG
