This is why retards shouldnt own Corvettes...
First off, Jay, stay out of this.
Ok. I didn't want to mention it but I was thinking about turbo charging my Vette. I got to thinking about it and how in efficient even turbos are (compressor efficiencies of about 80% at best).
Since a turbo's function is to pressurize incoming air and force it into the upper motor, and turbos are driven by high pressure exhaust gas created from the combustion process, couldn't I just bypass the turbo altogether and route my headers back into the throttle bodies?
Since I have CFI, I could balance the DEI (direct exhaust injection as I just coined it) by feeding one header into each throttle body. Yes, the charge air wouldn’t be that cold, but it would be under a hell of a lot more pressure.
I attached a quick sketch below:
There are still a few things I need to work out:
1) How do I get the CFI aircleaner to fit in a way that hides this plumbing?
2) Does anyone make a V-band clamp that will bolt an exhaust header to a CFI throttle body?
3) What pinion angle should I use in my rear-end? I’m sure there will be a noticeable difference in torque output.
What do you guys think?
LAwl.
nG
I hope he does it and posts back with the results.
Ive seen somone at alitimas.net convinced to take a sander to 'polish' his paint //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
He actually went through with it and wasnt too happy.
OoMesKoO
Me > Newbs. :fyi:
OoMesKoO
Rhode Island
regal8r
