these 3
wich out of the 3
  • elemental
    Votes: 7 25.9%
  • adire
    Votes: 10 37.0%
  • re
    Votes: 10 37.0%
  • Total voters
    27
JHS_2005
i have decided on these three subs
1. elemental sp 15's
2. adire brahma 15's
3. re xxx 15's
each will be powered by a dei 1100d, i want a sql setup with enough spl to hurt my chest but very accurate can any of these drivers achieve this? and it the esp15 underrated
3. re xxx 15's
if you go to JHS, in Jupiter, Fl then in about 2 weeks you'll be able to hear my XXX 12. e-mail me at chumpppp@hotmail.com
You also need to consider the ohm your running the speakers at.....
2 15 SP's are dual 4 each, meaning 1ohm total, or 2ohm for each driver = not total power from the DEI amp if you already have.
15" Brahma will match amps well.
Be sure to check everything before you buy to make sure it FITS into your stereo and for the amps/room you have before buying.
Ben
Originally posted by kaosmoon You also need to consider the ohm your running the speakers at.....
Ben
Will I have a problem with hooking the XXX up to a Rockford 1000.1?
Originally posted by XDrkmanX Will I have a problem with hooking the XXX up to a Rockford 1000.1?
well that all depends. I don't know anything about the rockford 1000.1. But the XXX can only be hooked up to 1 ohm or 4 ohm, so you will either need an amp that is 1 ohm stable or one that can produce alot of power at 4 ohm.
JHS_2005
JHS_2005
USA
Alphafrog1
