THE Thread
Well my 8v preouts scare me. This thing never heard of that //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Don't worry, the amp I'm running is from the tape-deck era aswell //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Input knob only goes as high (low?) as 1500mV, but I'm running an Eclipse 8053 into it with no problems what-so-ever. I can actually turn it up to full volume with little to no clipping (not with 0db sine waves, but with regular music).
Well when I had it in to see if it even worked, it either clipped or put out too much volume at like 2/3 of my system at normal (Eclipse 8443) normal max is around "68" when I had this amp in it was like "46". I want to try to use the high level inputs on it, just need to figure out how the 3 ports for it work.
On a side note to squeak.
When I was trying it out I put in Tracy Chapman's first CD and OMG did it sound good! The highs were a bit softer (good thing 'cause the Boston tweets are a wee bit harsh sometimes) and in one song the snare drum was like, perfect. I was like wtf. I thought my 80 per channel PPI was enough as I was guessing it to be much closer to 100 on 14v, but the extra 20-40 watt worked miracles on these comps I think.
You running Pro's?? If so, 100w wasn't nearly enough for them. Send them 200w and they just barely start to come alive. Send them 300w+, and you are in bliss //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
RangerMan
Premium Member
Premium Member
RangerMan
NC
x2o
