The SSA 10" DCON subwoofer's TSP
TheBassDr
Utah
DCON 10 Sound Solutions Audio 10" 300W DCON Series Subwoofer - SSA STORE
^Here's what it is^
I just wonder if the Sd can be anywhere near accurate. The Sd of my two 10" subwoofers is about 78in^2 or . I would like to give them a try because of the nature of their Theile-Small parameters and how well they seem to fit into a 1/4 length transmission line's needs. i.e. the low Fs, Qms& Qts are within the recommended range, and the 121.65in^2 Sd. Hopefully i'm not just misinterpreting this and there is truth to their ratings.
The site shows the sd to be 309cm^2 or 47.89in^2. Where did you get 121.65? That would be between a 12 and...maybe around a JL 13.5.
121.65/3.142 = 38.71
sqrt 38.71 = 6.22
6.22 * 2 = 12.44
The 47.89 comes up to around 8 inches which would be about right for a 10 inch sub. In any case, if your 10s are 78 or 39 each it would be a little more area for you.
Guys, let me know if I am off on anything here.
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
986
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
TheBassDr
TheBassDr
Utah
dacheatham
    May 16, 2024
    May 16, 2024
