The Saturn : )
Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And holy cow is the saturn sitting low right now...I just picked up 8 sheets of mdf (backseat) and filled up the gas tank...the back end's sitting pretty darn low, haha
Thanks ink //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And thank God for this interchangeable port setup though...I couldnt live with myself daily driving with something that peaks even in the low 40's...that'd just be weak, so I'll be making another port-wal here soon to hopeful run with next comp, probably looking to peak in the upper 30's or maybe around 40Hz..
one thing i noticed at the comp. u need someone sitting towards the front of your sunroof when u burp it or bassrace it. gettin rediculous ammounts of flex right there and im sure its hurting ur number a little.
Any reason you choose to tear out the power steering when doing the stock alt as to going through the wheel well? Your build is sick man; I've never seen this log before.//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
Thanks guys, and yea...the flex is kinda rediculous //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif hopefully soon I'll be deadening the crap out of my roof and doors (rear doors already have sludge on them, but im going to put probably another two layers of mat ontop of it)
I did at first..//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif But the alt couldnt fit through that way //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif...and it barely fit through from up top...ugh, it was down for a couple days working on that.
And hopefully vids soon, if I can get a decent one that shows some stuff happening //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I ned to borrow a better camera
got a question...isnt that amp like way more than that btl can handle?...or did u wire it to a certain ohm that is balanced...how much power is going to that btl...
also why all the wiring...and all the batts?...is that amp that power hungrY?
im still learning and you look smart...
Well, the power and ground runs are a bit overkill, yes...but more doesnt hurt, the main reason is if I upgrade like I plan to (basically doubling the equipment...in which case Id need the wiring)...and the amp can draw roughly 550 amps of current, and it's wired to 1 ohm...not wired higher
And for long periods of time the amp is too much, yes....but for burps it does just fine //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
BTW...that 2-week build on that van was pretty impressive //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif...I liked the moving store windows when you had it up with the doors open //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Pioneer~Saturn
Dr. Enclosure
Pioneer~Saturn
Dayton, OH
Pioneer~Saturn
