the rabbiting carpeting technique?
302yota
i know when attempting this technique, you are supposed to go over the side plates of the box with a rabbit or straight bit before assembling the box....but is it ok to go a head and assemble the box, followed by cutting out the groove with about 3/4" border.....if this is ok to do i think i'll make my groove with a staight bit in my rotozip about 1/4" deep
I do 1/8" x 1/8" all the way around each side panel using a flush trim bit in a router table. Makes carpetting the sides MUCH easier...
I do the same but with my smaller table saw.
well i just bought a black and decker router from a friend, for 25dollars...so if i prolly should start using it instead of the router, i can........but what size/kind of bit, should i used to make the grooves??
302yota
302yota
rockingham, NC
302yota
BP1Fanatic
BP1Fanatic
