The new RF power amps=sexy
jrouter76
jrouter76
I have to give credit when it is due,I have not been a fan of RF amps since they stopped making the DSM series,but the new T1500-1bd is the shit.It has a small footprint and it is powerful too 1500@1 ohm, what i like about it is it is small enough where you can run mutiple amps and not worrry about space plus I like the simple-sleek look, you know for me to be talking about RF amps it must have caught my eye just right here is some info: Description Value
CEA-2006 Compliant
Number of Channels 1
Rated Power
continuous power 500W x 1 @ 4-Ohms RMS
1000W x 1 @ 2-Ohms RMS
1500W x 1 @ 1-Ohm RMS
Total Power
total sum of 'rated power' 1500 Watts
Bridgeable No
Crossover Controls Low-Pass (LP): 35-250Hz 24dB/octave Butterworth
Tone Controls Bass: 0dB to +18dB @ 45Hz
Infrasonic Filter: -3dB @ 28Hz 12dB/Octave
Signal Input Low level: 1 RCA pair
Signal Output Low Level: 1 RCA pair
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote Punch Bass EQ
(overrides built-in Punch Bass EQ)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class bd
Frequency Response 20Hz to 250kHz +/- 0.5dB
Shipping Weight 14.35 Lbs.
(6.50 Kg.)
Dimensions (HxWxL) 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)
Dimensional Diagram
I think they look sexy as hell, I'm thinking of picking one up if the birthsheets are around or above the 2000W mark. I need about 2000W and I already have the new Power T400-4 4 channel amp. I know the old power amps the 2000W amp was more like 2800w on the birthsheets.
That's a lil far fetched to rate an amp -800w..........Try again.
jrouter76
jrouter76
jrouter76
Mount Vernon ,Illinois
regal8r
