The minimal distance between the sub(s) to a wall/glass.
SimonLTZ
Hi
I'm gon'na install 4 Kicker Comp-VR's in a sealed 200 Litter box.
i have 2 questions:
1. Should i seperate each sub in the box by a wall (thus making it 4 indepented 50 Litter boxes), or should i put the all 4 subs without any seperetions?
2. As in the title, is there any minimal distance between the subs to the glass in front of it? the car is a 1998 hyundai tiburon, and i designed a box that is very close to the glass. doe's the pressure between the sub to the glass could do any damage to the sound they produce? and what about the air flow from the trunk to the passenger cabin, it will be minimized too.
in other words, doe's the air that the sub's move finds it's way to move forward, without being depended in the pressure of the air in the trunk, or is it does depened?
Thank you for helping, Simon.
HiI'm gon'na install 4 Kicker Comp-VR's in a sealed 200 Litter box.
i have 2 questions:
1. IT doesn't matter per se but you definately need bracing. If nothing else divide the box into 4 compartments and cut holes in the braces...
SimonLTZ
SimonLTZ
Israel
AcidicDreams
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
