Patthehat033
I am a bit confused on how an amplifier "amplifies the current".
Okay so if you have 12V plus say 30 AMP's going into your amplifier from your battery. You are putting in 360 watts of power.
When you add the coil to the process you increase the voltage say to 24V and now you are only working with 15 AMP's. These are probably not realistic numbers but that is besides the point. What is the point of increasing the voltage if the wattage is the same?
Or do I have my math wrong does the voltage go up and the amp's stay the same?
