The Big Three Question
BEEKAY
US
So I decided to finally do my first system install this year. I am planning on doing the big three upgrade but had a question about it. Is using 0 gauge for the big three upgrade and using 4 gauge for the amp power wire pointless? Just to clarify I am thinking about getting a negative battery terminal with 2 0 gauge slots for the grounds. Then get a positive battery terminal that has a 0 gauge (for the positive to the alternator) and 4 gauge slot for the amp in the back. Any help to maybe help me understand a little more is appreciated.
It's never pointless to use larger power wiring anywhere. And depending on how much power you're running and whether or not your 4 gauge is a) true 4 gauge and b) CCA or ofc, you could be fine with it.
As for your terminals, I would just get dual 1/0 terminals all the way around, because you can terminate 4 gauge in a 1/0 slot with no problem but you cannot upgrade to 1/0 and shove it into a 4 gauge hole.
Also, if you share what equipment you plan to you run, I can give you better advice. ;-)
^^^^ this ^^^^
Well for right now I will just be running 2 P2's at around 600 watts each. I do plan to upgrade in the very near future. So it would probably be beneficial to just do the big three with 0 and just use 4 gauge for the amp for now, correct? Oh and my 4 gauge is from Rockford.
Thanks for all the other replies guys, I appreciate it.
Use 0ga all around, even for the amp. It's better to have wire that's bigger than you need than wire that's too small.
You should be fine with that man.
BEEKAY
BEEKAY
US
BEEKAY
BP1Fanatic
BP1Fanatic
