the whole thing im trying to avoid though is tearing up my carpet, so unless there's another way...but i think if i added another battery it should be more than enough
i wish i had a van...or an suv...or a truck...why do i have a car? and a bmw? and a battery in the trunk? all of these make car audio installations so much more complicated and tedious...anyone want to trade vehicles? hahaha
Adding another battery will only make things worse.
When your lights dim you're going from one voltage plateau, 14v from the alternator, to a lower voltage plateau, 12v from the battery. You can add a dozen batteries, you'll still have voltage drops. Even worse, a battery needs 13v or so +7A of power to maintain charge. If you add another battery you're just adding another load on your current charging system while not addressing the light dimming issue. If anything, it'll make the problem WORSE while needlessly draining your bank account.
1/0 is a waste and is a PITA to work with. Your car has factory 4ga, right? Adding another run of 4ga in addition to the factory wiring will yield the same resistance as replacing everything with 1/0. But people have it ingrained into their thick skulls that 1/0 is better for some reason. I've never understood it...
I still say you should turn your gain down a bit and fiddle with the subsonic. And while you're tuning, crank things up and feel if the factory power/ground wires going to the battery get warm. If they do, then add another run of 4ga. If they don't, don't worry about it and do something stupid like tearing your car apart to install CCA 1/0.
BMWs, in general, trap a lot of bass in their trunk and it causes people to go overkill with their systems and use the gain knob to compensate. If you're certain everything it tuned properly, I still say buy a quality 1 farad cap and see if it helps. A cap & a few feet of power wire will run you less than $50 if the cap is used. If it doesn't work, sell it for what you paid for it. If it does work, you're done. Just stay away from the junk with blinking lights and boasting a lot of capacitance for $20. Monster, Rockford, Stinger, Streetwires, etc. all make a decent product that works as intended and can be found dirt cheap on
ebay.
