(thd)total harmonic distortion
djjdnap
FreakyFreaks ofall Freaks
1,968
indy-nap-lis
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif Now I now what ehe definiton is but does this actually matter in choosing my amp or subs I'm really not shure. But it said 900 x 4ohms at 0.03%thd
Now it definitely doesn't sound like 900 whats to me, So if anyone could posiibly explain this concept or tell me if it makes a difference or not. I read it can also be read as DB decibels and I know thats for subs and 90 is like average for that I do believe.
I don't know Help Comemments whateva you got...
You can deal with higher harmonic distortion levels out of your sub amp. Harmonic distortion is harder to pick up on at lower frequencies. And from what I understand, THD typically doubles when you move from 4 Ohm to 2 Ohm. I think THD under .10 is inaudible.
well that doesn't make any since since it said 900 watts at 0.03%thd so how can I not hear 900 watts. OR does it not mean anything coherent to my problem??
by the way I had to llok up inaudible then it sent me to audible bewcause it said not audible but audible means to hear so inaudible must mean not able to hear.
This is for other readers who have no Idea what inaudible meant .
it just means that any level under .10 can not be detected by hearing it, only testing it. You would not hear anymore harmonic distortion at .07 than you would at .00007.
I believe the audible THD is higher than that (0.1). Every piece of equipment in your system has some distortion, added together to get the total. HU, amp, eq's, xover's etc. I could be wrong.
I think RC once said that in practice the number was 2% or so.
I also remember it being ALL of your equipment added together, like you said. I just can't remember how much your amps THD rises when you bridge it or go 2 ohms. I think we don't know certain details about it Mark because its never been a factor for us, lol.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif It really only matters when your using many processors, equalizers and amps with high THD ratings. Or just one REALLY cheap amp pushed too hard.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Okay I did some research..........THD below .10 is inaudible. So wes, you are right, I checked a few amps out some RF, MTX, Kicker, Sony, etc. and a few others and they were mostly around 1-2 THD. So if that planet audio 1200d is .33 Thd, that's pretty good compared to some of the other class D amps.
I do not remember that HU at all. I do remember that Crime Stopper had features like those but not controlling the HU? Clifford alarm system would...
Thanks! It may never have made it to U.S. retail. Actually, I highly doubt it! They have diversified their product line now as can be seen on...
The next time it happens check the voltage directly at the Boss radio. If it has 12v on both the red and yellow wires and the black wire is...
662
djjdnap
djjdnap
indy-nap-lis
Phatillusion
    May 31, 2024
    May 24, 2024
